View the thread, titled "Worcester Greenstar 24i Junior HW problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
W
wearemogul
I have a Worcester Greenstar 24i Junior, just recently we have been having a problem with the hot water.
When you turn the hot water on the boiler kicks in and it starts to warm up but then the water goes cold, also the pressure on the boiler jumps from 1.5 to 2.
After a bit of investigation the diverter valve motor, doesn't move, when you turn the hot water on.
But all i have to do is turn the boiler off, take the diverter valve motor our of its housing, turn the boiler back on, try it out of its housing and the hot water works again, so i put it all back together and everything works fine.
It works fine for about a day and i have to repeat the process, i am thinking of buying a new diverter valve motor, but its doesn't seem to be broken as it works after the above process,
Any Ideas?
thanks in advance.
Are you Gas Safe registered?
You need to be as you're taking the case off a room sealed gas appliance.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. http://www.ukplumbersforums.co.uk/im...-gas-engineer/
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Worcester Greenstar 24i Junior HW problem" which is posted in UK Plumbers Forums on Plumbers Forums.
