C
Corinda
Hello,
I have a Worcester Greenstar Heatslave Combi boiler for my oil-fired hot water/heating.
It's been ages since I've needed to alter the pressure and - being a real non-techie/impractical person - I've forgotten what I need to do to increase the pressure.
Just as background, when I checked recently, the pressure had dropped, so I opened one of the two taps on the pipes to increase it. However, the tap was very tight and I managed to over-pressurise. I bled the radiators, but now the pressure's too low. (What seems to haooen is that the poressure is too low when the systenm is off, but, when I fire up the central heating, it moves past the red cut-off point and into the 'danger' zone', if you see what I mean. Water then leaks from the outside combi to reduce pressure etc.)
I'm not sure if the taps/valves (or whatever they're called) are set correctly. Should they be parallel to the pipes to which they're attached? Or vertical - at 90 degrees?
I think I'm right in saying that if I open the tap on the right of the gauge, it increases the pressure. But do I need to open the other tap? (The last time I did, the pressure shot up too high. The tap on the left of the gauge is incredibly stiff. Once I move it, I can't move it back quickly.)
I'm sure I've got confused and done something (or not something) I should/shouldn't. Please forgive my ignorance.
Before I call in a plumber, I thought I'd ask here in the hope that the solution to my problem is simple. (Ie that someone can give me simple instructions as to what I should be doing with the taps. It's best to assume I know nothing and I'm doing everything wrong. 🙂 )
Many thanks in advance, if you are able to help me.
James
James
