SlimD
Hello,
I'm hoping that some of you mosre experienced guys can help me. I qualified and got Gassafe this year and it's been a steep learning curve as I'm learning something new with every job .
However, my in-laws Greenstar has me baffled. It starts to fire up but doesn't get past the 45 second stabilisation period. Instead after about 30 secs it makes thumping and hissing noises then the green light goes out and it waits a while before trying again.
It's on a Y-plan system and I get the impression that there's not enough water flowing through it and it's over heating the water, hence the hissing & banging noises. The pump had seized so I replaced that thinking it would cure it, but no. I've also manually opened the 3 port valve in case that was stuck and restricting flow to the boiler.
It's probably something pretty obvious but it's been a long week and I'm tired and fed up with scratching my head so would appreciated any suggestions from anyone who's familiar with these boilers and can put me out of my misery.
Thanks in advance.
Thanks in advance.
