View the thread, titled "Worcester Heatslave 2 CH control" which is posted in UK Plumbers Forums on UK Plumbers Forums.
stevered
I have a brand new Worcester Heatslave 2 oil boiler complete with a wireless DT10RF controller fitted. The feed to the existing CH system is via a 2 port motorized valve. A new UFH heating system is being installed with a single two port motorised valve on the hot feed to the manifold and a pump between the hot and cold manifolds. A separate wired thermostat/controller will be fitted in the UFH area.
My question is the how to wire the system to allow the two areas (CH and UFH) to trigger the Heatslave Boiler separately and if required, together. Is this possible using the DT10RF and a separate UFH thermostat/controller? Is there an off the shelf wiring centre for this purpose?
Many thanks for any assistance.
I think you're after independent control of the two zones. You will not achieve this using the DT20RF speak to the installer who put the boiler in.
Reply to the thread, titled "Worcester Heatslave 2 CH control" which is posted in UK Plumbers Forums on Electricians Forums.
