View the thread, titled "Worcester junior 28i no hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
F
fuzzy
Worcester junior 28i is working on heating, working on hot water when heating is on, but hot water will not fire up on its own.
The boiler is showing no fault lights and tries to go through its cycle and stops, tries again then stops.
Any ideas?
only happened this morning so not even looked at it. i thought flow switch, i know where there a like of rlike boiler not being used. may try and swap the flow switch and maybe diverter to see if that fixies it.
wondered if anyone had this issue with this particular boiler and if it was a common remedy for it
well, it was easier than i thought. boiler in loft, checked it and the pressure was down to zero! not sure why it fired on ch and not hw? never mind sorted now, thanks guys
Reply to the thread, titled "Worcester junior 28i no hot water" which is posted in Bathroom Advice on Plumbers Forums.
