View the thread, titled "Worcester Junior condensate seals" which is posted in UK Plumbers Forums on UK Plumbers Forums.
AllyBongo
Servicing a 4 year old Junior today, the rubber seal on top of the trap didn't want to seal again. Had this before on a Ri, greased it up and it was fine. Had this one out 3 times adding grease and turned the rubber round, just kept letting a little condensate out. Ended up using a little clear silicone which seemed to do the trick....
Any tips for these?
Thought of that but a quick scan on Parts Arena only shows the whole trap as being available, where do you get your seals from?
i get mine locally but its only a bit o ring so once you have the size you can get them easy
Reply to the thread, titled "Worcester Junior condensate seals" which is posted in UK Plumbers Forums on Plumbers Forums.
