Kewat66
Hi All,
Just looking at a problem on a Worcester Junior combi. It's a junior. The pressure sits just under 1 bar. The boiler seems to work if no heating is on, so the hot water works, I have turned the heating off. If the heating comes on, the boiler builds up pressure going up to about 1.5 bar and then releases going back down and then the warning light flashes until it is reset. It does this within about 10 seconds from the heating coming on so hopefully you will be able to see this when you come. The while cycle of going up and down happens within a couple if minutes. Any possible suggestions?
thanks
kewat66
thanks
kewat66
