View the thread, titled "Would this be ok to run a high pressure shower?" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
WaterTight
Subscribed
Don't know anything about them. She has heart set on overhead drencher type shower requiring combi/HP set up. Didn't have time to measure pressure but kitchen hot seemed to have very decent oomph when turning it on.
Is that boiler a combi ???? Never heard of these don't know why but looks like a baxi solo lol. If that is a combi then you can treat it as a combi.
it's a "multi point water heater"
i don't know if that is just an old name / early version of a combi or something a little less and therefore with special considerations for running showers etc
Aqualisa say as long as it is a "minimum of 24 KW" it will be fine.
The instaneous heater manual says it has:
Heat input nominal: 23 kW - 78,480 Btu/h
Heat output nominal: 21 kW - 71,650 Btu/h
Is it the input or output that they would be referring to and how close makes no difference in this case? Or can 1-3 KW (depending which one they'll mean) make all the difference?
I imagine they are stating a minimum appliance kW to guarantee a minimum flow rate and to ensure a warm enough shower will be able to be delivered.. Ie to heat water by 35 degrees which is the industry standard for instantaneous water heaters with a 24kw appliance it will deliver that at 9.79 l/m. However this does not allow for heat/energy wastage as this is an input calculation so the flow rate will be infact lower than that but average correction factors can be applied. I think they would be referring to heat output (net) rather than input (gross) as it will then guarantee a minimum litres per minute. Ie 24 kW will deliver X ammount of water a minute at a minimum temp of X hope this helps.
Blimey, youngsters today!
The whole country used to heat their water with Britonys, Ascot and the Main "River" series - Trent, Severn, Medway, Mersey etc.
Just think of it as a combi on summer setting. It'll be fine.
Incidentally, the Britony IIT was that rarest of things - a market leading product from Chaffoteaux et Maury.
Brilliant piece of kit. Chaffoteaux went wrong when they started putting electricity in their appliances haha!
Reply to the thread, titled "Would this be ok to run a high pressure shower?" which is posted in Showers and Wetrooms Advice on Electricians Forums.
