View the thread, titled "Y 22mm Strainer / Filter & Boiler Flush" which is posted in Boiler Advice Forum on UK Plumbers Forums.
W
wildhorses
HI All wondering if anyone can help with the following Q's
I've an Open Vent Central Heating System with a heat only boiler, if I were to fit a 22mm Y strainer in there would the best place to put it be on the reverse rather than then flow. I only want to put the filter in for short periods so when I'm done can I remove the strainer from the Y and just put a blanking plug on it? hence not causing any restriction again.
i.e. when you take the plug does the whole strainer basket come out with it or is any mesh left inside
How much restriction do these actually cause?
Also can any damage be caused to a boiler by reverse flushing it
thanks
He means a Y strainer.
Be better with a system filter. Take your pick from the many available.
I mean one of these CHECK VALVES & STRAINERS & DRAIN COCKS
I have not got room for a system filter (i'd have to remove by kicthen cabinets or install it inside the cabinets!) ( but can squeeze a Y in, if anyone knows how these come apart can you let me know please
thanks
I would say these would get blocked quite quickly with central heating. if you can get this in try a TF1 mini filter or magnaclean mini filter, better then these I would say
A Y strainer will block quickly and lead to no flow. You need 2 valves either side of the filter to enable it to be cleaned so it takes up a fair bit of space length wise.
System filters are designed to allow the flow to bypass the filter if it blocks. Easily cleaned.
These are about the smallest, spirotechs are slightly deeper.
Reply to the thread, titled "Y 22mm Strainer / Filter & Boiler Flush" which is posted in Boiler Advice Forum on Plumbers Forums.
