steveboy
Hi folks ,The problem i have is that when the programmed time as elasped the (honeywell mid postion valve) stays in its last postion ,this causes it to get hot over night and i read somewhere that this isen`t good for them as over time it causes them to burn out .I have checked and double checked all the wiring and seem to have got all the wires from the thermostats in the correct configuration with the boiler ,programmer and valve. MY main question is this " Is it normal for these type of valves to stay in its last position or should it wind back to default position using its return spring when the programmed time as elapsed?
One other thing the boiler still keeps running even thought the room stat is satisfied (within the programed time though)🙁
I have been pulling my hair out for over a year now over this problem ,its not so bad in the summer as only the DHW is called for and the valve doesn`t move but now its winter and both CH and or DHW is called for the problem is back!!!🙁
many thanks and festive cheer🙂😕
steveboy
steveboy
