Discuss 0.5mb drop on tightness test - Should I be worried? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Well you don’t as you’ve said you test gas carcass at 1 bar which could hide a small leak
Don’t think I ever mentioned that I test pipes in uk with 1bar. Yes I agree, I did say I would and that would be the appropriate way to pin point leaks, hairline cracks etc. But I never said I do and don’t stick to the uk rules. It’s a slight difference of having an opinion and doing it as I said I would. However, you won’t get my point as you always seem to look for excuses. Just admit for once that other people are right too and know their trade. Or are you to proud
Yes, you would need to otherwise you will ruin the appliances. You can only test them via there operating pressure as you know. But when it comes to testing the pipework throughout the property when installed new then you will need to use the appropriate fittings to cap them off and test them with higher pressure ( but that’s the way we do it in Germany ). We do 2 test before bedding pipes into the concrete, load testing ( 1bar with air or N ) for 30min -1hour and then a 15 min test leak test.
Sorry but it is difficult to explain german terms in English. I think you can’t be careful enough when it comes to gas. I know it’s done differently here and I do whatever is required but I would wish few things would be different.
This doesn’t sound like an opinion mate. It sounds like standard practice.
Nothing against Germany mate. It helped make England strong before we were properly part of the E.U;):p:p. At my moms house I am allowed to walk around in just my pants. Does that mean I can do it everywhere else?
On open forum I would be like you mate :) not all the things which we are allowed to do are the rights things to do. Regulations both in Germany and England could be still improved.
Does Germany have an equivalent to gas safe?
It is slightly different compared to uk. Most people works for companies rather than being self employed. You will need a master degree to be able to run an own business. However, each company and installer needs to be registered though.
Let’s get this right, you need a masters degree to start any business up?
So if in that situation, you had a 3mbar drop on a g4 metre, your conscience gets the better of you and you decide to investigate. You isolate the appliances and prove the pipework is sound. You then test each appliance individually and find the gas valve on the fire is passing. What then? Do you leave it or have to condem it?
Once you have gone down that route thats it. I had a gas sqfe routine inspection not long ago and I had a 0.5 drop on the job he came out to. The gas safe guy confirmed no smell of gas on existing install its a pass. If I had decided to isolate appliances I would be obliged to find it.
Reply to 0.5mb drop on tightness test - Should I be worried? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am a homeowner but caught between a rock & a hard place. I am trying to get a Vaillant ecoTEC 630 plus serviced but the gas safe engineer &...
2K
Good'ay Wondering what I have been doing wrong or what I should be doing differently. Have had some jobs lately where I will carry out a gas...
New LPG installation with 2x 19kg cylinders outside, plus change-over regulator with isolator valve on output, then 10 metres of 15mm copper pipe...
2K
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I...
J
    • Love
During Covid I had to undertake a phone consultation to pass my Gas Safe Inspection. I failed dismally even though I have over 35 years...
2K
Deleted member 120897
