Discuss 10mm angled tap connector in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Does anyone know where I can get such a thing? The cistern in the old toilet is 10mm. Having a nightmare on this job I am. Grr
What are you trying to do?
You get get a 3/8"x 1/2" brass bush that will screw into a 1/2" bent FI adaptor
You can get a 3/8"x 1/2" brass bush that will screw into a 1/2" bent FI adaptor, and that will allow you to connect onto the old 10mm ballcock and re pipe in 15mm
Reply to 10mm angled tap connector in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm...
Hi Anyone know of a pull out kitchen tap that has decent pressure? I have had low pressure from this tap for a number of years and it's not...
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use...
Think I know the answer is no but asking just in case. I have a solvent weld bathroom waste with lots of connectors in it that disappears into...
This is going to sound stupid - but it is giving me problems. I have fitted new flexible tap hoses that each connects with a tap hose adaptor to...
