Discuss 10mm Heating pipes - lagged in loft? in the USA Plumbers Advice area at PlumbersForums.net
Hello,
10mm copper heating pipes in loft were lagged with felt. Have extended the pipes with plastic. I I an assuming that plastic 10mm pipe in loft space should be lagged as it can still freeze. Do I just use felt wrap? What do you guys do with plastic 10mm heating pipes in loftspace? Thanks for any advice.
Yep needs to be lagged could be something simple as getting a roll of insulation and putting it onto of the pipes etc
Reply to 10mm Heating pipes - lagged in loft? in the USA Plumbers Advice area at PlumbersForums.net
