Discuss 10mm rad pipe and fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
-=HaZ=-
Hi
I'm taking a radiator out in a newish build and have noticed it's on the flexible pipe that new builds have now.... I'm sure its 10mm but may be wrong.... They have yellow elbows attached to them that go into the valves and then into the wall
What's the name for these elbows fits anyone know so I can look for them as I will need a couple when I cut the pipework
Chances if they are plastic they started life in white and have become discoloured as for the conversion to the rad valve they are called stem elbows
Cheers guys..... Had a closer look today and I think they are stem elbows.... One side pushfit and the other a straight bit to attach the valves onto
Will sort them next week when the fixtures go in
Reply to 10mm rad pipe and fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
