Discuss 110mm plastic pipe fitting toilet solvent in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
N
nadeem
Hiya, my toilet has 110 pipe going to master boss fitting. It's not glued and loose. I think as it's going to master boss that's why it's never glued. It has one drop of water leak after every flush. What I can use to stop leak at same time in utue if It needs to be removed it can be removed without ajor cutting.
Any pictures of the leaking bit ?
Reply to 110mm plastic pipe fitting toilet solvent in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
