Discuss 2 rads dont work? blockage ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
marsaday
I have a rad on the ground floor in the front room not working and a rad above this room in the bedroom not working.
There are 14 rads on this system and 3 rads in the basement area have been shut down completley, to try and rebalance. we have also closed the other rads by 1/2 a turn.
What could be the problem with these 2 rads ?
When you say air lock, does that mean the rads can be bled. i have tried this an there is no air to come out.
If it is an air lock somewhere else, how do i get it out ?
i know it's cold but turn off all the rads that are working to force the pump to serve the rads that aren't working to force the air out through them bleed thge rads and see if that helps.
Do the rads have Thermostatic valves? If so the pins might be stuck
Reply to 2 rads dont work? blockage ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your help please. I've extended an existing 'run' of radiators - the last one on the run ( in downstairs kitchen) is cold. The first rad added is...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or garden, run-of-the-mill British housing estate CH setup. Downstairs radiator, 1 of 2 in our living room, went cold one evening mid-November last...
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs covering at leave twice the floor area As per diagram has free flow Up or Down, no way to balance. Works pretty well but last few Rads (in kitchen) are...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also have an UFH zone in the kitchen. Near the boiler I have 2 port valves which control this part of the system. The boiler has been loosing pressure...
Hi, I have a sealed system with 18 Rads/towel rads which is run by a greenstar boiler with a sealed hot water tank. I'm using a tado thermostat and the Pump is a 15/50 Groundfos. The issue is there are two radiators that are cold. So I closed down every radiator except for these two, apart...
2K
