Discuss 24i RSF intermittent fault help in the Central Heating Forum area at PlumbersForums.net
Nas
Basically the boiler stops working intermittenty for heatingand water... It had a leak from auto air vent which was dripping into the APS which has been repaired..
Everything seems to be working I've tested the harness to the APS and the overheat stat. and out of desperation changed the PCB ..
When its fails to ignite the fan can be heard running and the APS works but it doesnt kick off the sparking sequence
any pointers would be appreciated
Reply to 24i RSF intermittent fault help in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
