Discuss 3 824 question, bit of a poll really. in the Central Heating Forum area at PlumbersForums.net
Apart from this site being TOTALLY SWAMPED with so many adverts one cannot access it properly, here's my lovely question, should I ever be able to read it.
The good old 842, this one's an eco max, got called out to CH not working but DHW is,
Now I done the normal, the div was shot, so changed it, done a check on the vessel, full of water so changed that too, naturally.
Ran it up, all good. FOR TEN MINS LOL!
and then it went back to just dhw, so, I isolated the div, blew off the system pressure and again, put the required car in vessel, charged system again etc.
It ran for 3 mins on central and then just shut off again, ( bearing in mind ,dhw is ok)
Oh! Pump is well good, as when it was going it hit the farthest rad no problem!
Would I be mad in thinking just a dead NTC ?
A little vote on this would be fun to see who was right!
Cheers guys.
All my best.
Reply to 3 824 question, bit of a poll really. in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
