Discuss 3/8s toilet fill valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
If a toilet has a flush valve with a 3/8s thread. Does this mean the hole on the cistern is smaller? I want to fit a 1/2 threaded one in it.
Thanks so I still never did this job is for a. Friend. If I get the 3/8s one so will fit through the hole in the cistern. I would then need to get back to 1/2 as the supply pipe is really tight and tiled in I need to use a 1/2 bent Flexi. They don't do in 3/8s. So I could use a 3/8s to 1/2 bush to take back up to 1/2? Sealed with locktite 55 cord.
Correct or use what the original used etc
Reply to 3/8s toilet fill valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi All, does anyone know why the water only fills 1/3 of the way please?
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
