Discuss 3 port on under floor yellow light blue valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
southcoastboile
I need to replace a 3 port on an underfloor circuit.
its blue and has a yellow light on top of the box.
does anyone know the make of valve and if I can replace with a standard 3 port?
thanks
Horstmann?
Horstmann Z322 3-Port Motorised Valve | Motorised Valves | NoLinkingToThis
It's similar to that horstman one but not the same. I'm fairly sure it's just a 3port at her than a blending valve but not 100 percent and don't want the hassle of changing it and it not working I would rather do another job instead but I don't like letting customers down either
Reply to 3 port on under floor yellow light blue valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey, I've got a leaking toilet and I need to replace the filling valve device which is a Geberit 810.L3 Type 340 with a 1/2" connector. Problem I've got is the connection under the tank (image attached). The top plastic nut (yellow) is only to hold the fill valve in place - I can undo it by...
We have a Daikin Air Source heat pump feeding our hot water and under-floor 8 port manifold heating system. The Daikin has just had its annual service and the engineer commented that the water looked discoloured and that the inhibitor needed replacing?? Is this an easy procedure? I'm pretty...
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs covering at leave twice the floor area As per diagram has free flow Up or Down, no way to balance. Works pretty well but last few Rads (in kitchen) are...
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to you? I suspect that my long ongoing rotting veg/sewage smell is caused by a fault in this connection that has been hidden from previous inspections...
I have a CH circuit on a 2 way zone valve. It’s a long circuit with 15 rads on it but rather than shutting down the last 5 rads in the circuit when not in use which is 90% of the time, can I put a 3 zone valve on the flow after the tenth rad and divert to a new T piece on the return to...
