Discuss 3 port on under floor yellow light blue valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
southcoastboile
I need to replace a 3 port on an underfloor circuit.
its blue and has a yellow light on top of the box.
does anyone know the make of valve and if I can replace with a standard 3 port?
thanks
Horstmann?
Horstmann Z322 3-Port Motorised Valve | Motorised Valves | NoLinkingToThis
It's similar to that horstman one but not the same. I'm fairly sure it's just a 3port at her than a blending valve but not 100 percent and don't want the hassle of changing it and it not working I would rather do another job instead but I don't like letting customers down either
Reply to 3 port on under floor yellow light blue valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
