Discuss 3 Way Electromagnetic Solenoid Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a steam shower and the 3 way solenoid valve has stopped working and I need a replacement. Original supplier has gone kaput. Does anybody know where I can find this or know any workarounds?
Much appreciated.
Good luck!
You may be looking at a new shower.
If there is enough space and inventiveness it may be possible with 3 washing machine inlet solenoids. Then again, I just found these:
Thanks Albatross. I wondered whether a washing machine solenoid would work. I phoned one of the companies, but I realized the valve needs to be DC 12V, which is lower than the washing machine valves (as far as I'm aware).
I get the feeling it might be more of a specialist part for steam showers?
Does anybody else have any input on this. I don't want to be forced to go down the new steam shower enclosure route; everything else is fine apart from this little part... surely somebody can supply it.
Whats gone kaput?
Rather than change the lot just try and source a replacement solenoid and fit to the existing body.
Whats gone kaput?
Hi Nostrum, thanks for replying. Do you know of a place where I can get a replacement solenoid (12V) which will fit onto the one in the photo?
Have you tried Maplin or anywhere online? Are there any markings on the solonoid as a clue?
I picked up a single 12V from some one like ADAFRUIT (Raspberry-Pi) related ,(Not sure if same size as yours ) .
[DLMURL="http://www.phenoptix.com/products/adafruit_plastic_water_solenoid_valve"]Adafruit - Plastic Water Solenoid Valve - 12V - 1/2 NPT # 997 | phenoptix | Open Source Electronics Kits and Components in the UK[/DLMURL]
Try solenoidvalvesuk.com. Looks like they've got some 12v ones in the plastic valves area
Reply to 3 Way Electromagnetic Solenoid Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
