Discuss 4 inch elbow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
Is this likely to be a solvent weld elbow?? Sorry for the bad picture..
I have to replace the pan connector but not seen this kind of elbow before so just sussing what I need.
Oops...
yea looks like sw bet there is no 4" pipe on the collar thats why its leaking
Are there no elbow pan connectors but with a long stem from the pan going to an elbow with a short male connector for the 4 inch stack...??? They all seem to be the other way...
extended bent pan connector and how long to looking for?
sorry imeant to say there are two sizes of bent pan con try the macalpine book to get dimensions the pciture looks like a pan con into an old terain pan connector which will work if you put a bit of 4 inch onto the second one
I can only find these.. I need it the other way around..
Basically as long as the elbow plus a few inches
I'm think I'm just gonna hack off the sw elbow at the base and stick in a flexi as I don't think the extended inlet pan connector is quite long enough... it only gives me 80mm for the inlet
can you leave the elbow in ? (split?)
Reply to 4 inch elbow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
