Discuss How to remove elbow in photo in the Central Heating Forum area at PlumbersForums.net
W
WayneC
I am replacing the radiator and need to solder a fitting new the existing elbow. I am concerned the heat will damage the elbow but have not seen this type before and would like advice on removing the copper microbore so I can solder a joint onto it then refit it in the elbow.
Is it similar to a Hep20 de mount tool? Looks much smaller
Can’t see how I add a photo
It’s grey in colour, no twist ends as all one mould and has a insert similar to Hep20
You can use the attach files tab on the right to where you click to post your question
Does it have a white / clear collar / upstand
Reply to How to remove elbow in photo in the Central Heating Forum area at PlumbersForums.net
