R
rick
Hi everyone,
I'm a new member and not a plumber or central heating engineer.
Mum and me live in a 1970 house she's had from new and the installed central heating is very primitive (no thermostats except the one close to the Concorde boiler, no zonal valves). As far as I know, it's never been cleaned. On the Concorde, the electronic ignition gave up long ago, but apart from that everything works fine. All radiators are hot, there's no leaks and none ever need to be vented. It's even got some ground floor underheating due to the presence of the microbore pipe runs! Maybe it's living on borrowed time? (there is a fair bit of kettling!)
Either way, looking to have a groundfloor extension made, so that Mum can live downstairs. Extra rooms needed for bedroom, downstairs bathroom etc. Therefore, will need to add extra heating and will look at the very least to change the boiler to go along with the extra piping and radiators. How further does everyone thing I should go? As it's microbore, should the whole system be replaced? Or, should the system be cleaned and flushed, radiator by radiator; then pressure clean the system as a whole; then change the boiler; then add the new piping and upgrade with thermostats? I've had a few opinions from both builders and plumbers. One suggested keeping the piping and changing the rest, the others to change the whole system. A major disruption to change the piping:- either buried in the solid ground floor or twisting everywhere under the upstairs floorboards. Your opinions all gratefully accepted!
RicK
RicK
