Discuss 8mm pipe to rad valves on a tight bend in the Plumbing Jobs | The Job-board area at PlumbersForums.net
They probably would do imperial sizes.
I can't remember what make mine is but rothenberg still sold them a few years back as one of the lads had a rothenberg one. The ratchet bender is a much better tool.
A brake pipe flaring tool might be what you are after for swedging the ends out.
This is the kind of thing i am talking about, hopefully they upload OK. IMG_4213.jpgIMG_4214.jpgIMG_4218.jpg
They have been done on a bender
Hell Tamz I would like to see that former, that is tight, doubt you could do that with today's tube, like you say looks like
a bender done that.
you can get valves with chrome m/f push fit bends to go in the bottom which give a nice finish for this situation
a bender done that.
A wee touch with the blow lamp and you could still do it with a spring. It would take longer to clean the pipe up tho :wink:
Reply to 8mm pipe to rad valves on a tight bend in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
