- Messages
- 34,367
- Solutions
- 2
For control via home assistant?No, I'm trying out an esp32 based ebus adapter that works with ebusd (I can't paste a link, sorry! I tried but it wouldn't let me post)
Discuss Accessing Flexicom 24hx installer cartridge in the Central Heating Forum area at PlumbersForums.net
yepFor control via home assistant?
Thanks, good to know Are you doing the same? Did you manage to change the flow temperature using the "SetModeOverride" method? So far I have it reading everything into HomeAssistant but I've not tried setting it via that method yet as some of the state I'm seeing looks a bit different to what I've seen online.Just a note you can’t alter the boiler temperature below 60 degrees
Right, yes that's exactly what I was planning on doing. Dropping the temp when only the UFH is active and raising it when the HW is on.Some what but the issue is you will need to do dual temp eg 60 for heating the cylinder up to kill legionella and then your desired flow temp for the rads eg 40
Hah ok thanks! It all seems to be working well now, but I'll keep an eye on itIf the boiler allows that the older gloworms were problematic to say the least don’t turn it off for long periods it might not come back on
Reply to Accessing Flexicom 24hx installer cartridge in the Central Heating Forum area at PlumbersForums.net
