Discuss Adding sealant to system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
cagdas alcicek
Hello,
I have recently installed a new boiler and my pressure is still dropping every few days. I've been told that its due to a leak somewhere in the pipework. I cant see any leaks on the radiators or valves, and the pipes are under concrete underground. I was going to add some Sentinel Leak sealer (this one to be exact) to see if it would fix the issue before taking any drastic measures.
I have a magnaclean filter installed. My question is, are these sealants harmful to this filter in any way?
Thanks,
Cagdas
I would make absolutely sure the leak is on the system and not the boiler before putting that stuff in it , I have never used it and never will , the lads I know who have used it have very mixed opinions on it . What boiler is it ? , did it leak before ?
Ive never liked leak sealer as was always under the belief that they werent good for the system although newer ones are not so bad ,,, now i dont know the facts on sealer so im just saying wots in my head but if i was going to use it and put it into the big magnet id check wots in the ingredients incase it sticks to the magnet lol
I was always under the impression that some manufacturers don't like it in there boilers and it voids the warranty, but I may be mistaken.
Out of curiosity, can this stuff seal up AAV's ?
like the one inside your boiler ?
Just asking because I don't use it so I don't know much about it
They say it's not supposed to but we all know it could :D
Reply to Adding sealant to system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not getting through to the boiler. The...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
I’ve recently cleaned my central heating system with Sentinel X400 cleaner, flushed it out clear, refilled & added Sentinel X100 inhibitor. After...
Hi I have recently bought a house which is 17 years old. There was a small leak from one of the radiators So I took the pipe off and drained the...
A bit of history first. 2 yrs ago visited a grant boiler with boiler and pipework kettling. I added SentX200 noise reducer. It is standard open...
