Discuss Additional system filter ??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
townfanjon
Subscribed
guys , I fit Magna pro 2’s and love them but I have two customers where I am pretty sure the towel rails are releasing cra* into the system and the filter is missing it because its not magnetic.
Any off you fitted a strainer as well as a mag filter ??
Cheers in advance
Cheers in advance
I usually use either spirotec or flamco filter. I don’t use a strainer when having a good Magna filter.
I know of two boilers which have had strainers fitted and both suffered from total heating failure due to them blocking up, the gauze is far to fine and collect far to much smaller particles. The gauze was swiftly removed..
Yes I can see that happening, I have no idea round this , are the gauze all one size ?
Cheers in advance
I would recommend the spirotech magnetic filter.
It filters to something small, very small.
Yes thats what I was thinking , but surely could only go on the towel rail return, rather than the heating return back to the boiler. Just look a Twa*.
Either tbh just need cleaning regular for the first few days if it’s that bad
That is what worrys me , I have a feeling its going to be on forever lol , cut a towel rail in half next time you take one off , you will know what I mean
Change it for a stainless steel one
Doesn't tf1 fernox have non mag filter as well as magnets? I thought it did.
It's sold as a total system filter but doesn't have a specific filter for non magnetic particles. Instead it apparently traps non mag particles along with magnetic particles using its "hydrocyclonic design".
Hydrocyclonic eh? For sure Dyson has a patent on it somewhere.
I like the TF1 Omega but I've taken the magnet off it and a Spirotech in the past and it still managed to trap a fair bit. Mostly it's down to low velocity turbulance created so the particles fall out of suspension irrespective of whether there's a magnet or not imo.
So I was intrigued about this and so I looked at what came out of a tf1 omega today to see for myself (Sad, I know). You get 2 "drawings" of particles from the filter, the first is entirely non magnetic the second is mostly magnetic. I kept them seperate. I have attached pics. The lighter plate is entirely non magnetic. The darker plate is mostly magnetic. A magnet was used to pick up the mag particles for demo. So it does trap some non mag. Probably just by creating a low pressure zone and allowing gravity to pull the bits out. As @gmartine says above.
Reply to Additional system filter ??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just had a new Worcester Bosch Greenstar 30Ri fitted with the magnetic filter. When the system is running the boiler is so quiet but there is a...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
Hi! I have mostly underfloor heating in my house and one new radiator and two old. A bit of metal pipes and three manifolds, but mostly...
