H
harry22
Hi, I want to replace my fortic open vented cylinder with a Gledhill Sunspeed 2 cylinder which I have bought secondhand. I currently use the fortic cylinder for hot water only using the immersion coil on ecenomy 7 but my bills are very high as the cylinder is poorly insulated. Initially I will just replace the cylinder but eventually want to add solar system.
I have attached a diagram and photos showing how I intend to set the system up but am confused by all the connections. There are three 22mm connections together on one side at the bottom of the cylinder and on the other side there are three more plus 2 small bleed type connections.
Can anyone explain...
1 which one is the inlet connection from the feed tank.
2 There will be a spare 22mm connection, what is this for
3 Is the rest of my diagram correct
4 I currently use a trevi boost which has a venturi valve and gives an excellent shower so am not concerned about pressures, but need to know what size header tank is suitable, is 25 gallon ok?
Harry
Harry
