Discuss Advice on corner TRVs in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
All the corner valves I can find seem to be random chinese valves of suspicious quality.
Are there and good quality corner TRV valves out there?
It looks like the major brands like drayton and danfloss only make angled and straight valves but not corner. Any thoughts welcome!
Drayton make corner bodies. IIRC you have to buy the body and thermostatic head separately. They work out quite pricey so everybody avoids using them so you'll probably have to hunt around to find a stockist.
Oh nice, found the part numbers in the catalogue
Drayton 15mm corner angle left EB 15 CAL 07 15 196
Drayton 15mm corner angle right EB 15 CAR 07 15 197
Both of them seem to have pin to be used with TRVs but I assume can also be used as lockshields with a cap.
Will try to source them, they dont seem easy to find.
Reply to Advice on corner TRVs in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
