Discuss Advice on fitting Honeywell DT20e thermo to combi MAIN 24he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nindy
Hello,
Not sure if I have to introduce myself on this forum or not so apologies.
I 'm trying to fit a Honeywell DT20 e thermostat to replace my old rotary Honeywell T40 one.
The DT 20e has two wires and is operated by batteries, as I understand it it requires a constant live and a switched live ?
So A= live & B= Switched live is that correct ? ( on DT20e the Thermostat that is).
After looking at the boiler manual ( MAIN 24he) It looks like I need to connect the switched live to terminal 2 on the boiler ( fig 43, from terminal B of the DT20e) & for the constant 230volts from terminal A of the DT20e.
No neutral required as it uses batteries.#
attachment.php
Could someone please confirm this for me ? Looks like the people before us have used household cable and when I put a 240v screwdriver on it the Brown cable and Blue wires light up when the heating is on. So in theory the neutral ( blue) wire is NOT really a neutral its a switched live on the old T40 Honeywell thermostat.
Any help/ advice appreciated please.
Reply to Advice on fitting Honeywell DT20e thermo to combi MAIN 24he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT I have three wires in the old...
Hi I’m looking to install the above. Atm I have an older one fitted (old wireless thermostat and old receiver that’s wired into my combi boiler...
Good morning all I hope you are all well? I am after a bit of advice please, I am looking to fit a Drayton LWC1 wiring centre into my boiler...
2K
I recently purchased a hive active heating. I currently have a Honeywell cm900 thermostat wired to my Worcester boiler. I'm just looking for...
3K
Hi - hoping someone can help with a what I think is a simple question! I have a Salus wireless thermostat connected to an Ariston combi boiler (a...
3K
