advise on flow and return points unvented cylinder compared to the height of the header tank
View the thread, titled "advise on flow and return points unvented cylinder compared to the height of the header tank" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Inverness
Hi guys, before I go ahead and install a indirect cylinder. The problem is in the loft where the flow and return points on the cylinder are similar height less than 0.1 bar to the header tank.
I'm worried about there might not be enough head from the top of header tank to the flow going into the cylinder. I could possibility move the header tank higher. Is there any thing else on the market that can solve this issue? Cheers
The title says "unvented cylinder", but you mention a header tank, which an unvented doesn't need. Can you be a bit clearer?
In any case, an unvented cylinder has to be installed by someone with a G3 qualification.
Heating side
Provided the primary circuit is piped boiler - open vent - cold feed - pump, I don't see why it would be a problem.
I installed a 200ltr last week with about 1m from bottom of F&E to F&R connections on UVHWS and it's working v well. (didn't need to alter existing CF or vent - was S Plan already).
Reply to the thread, titled "advise on flow and return points unvented cylinder compared to the height of the header tank" which is posted in UK Plumbers Forums on Plumbers Forums.
Inverness,
doitmyself,
