Discuss advise on flow and return points unvented cylinder compared to the height of the header tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
Hi guys, before I go ahead and install a indirect cylinder. The problem is in the loft where the flow and return points on the cylinder are similar height less than 0.1 bar to the header tank.
I'm worried about there might not be enough head from the top of header tank to the flow going into the cylinder. I could possibility move the header tank higher. Is there any thing else on the market that can solve this issue? Cheers
The title says "unvented cylinder", but you mention a header tank, which an unvented doesn't need. Can you be a bit clearer?
In any case, an unvented cylinder has to be installed by someone with a G3 qualification.
Heating side
I would seal the system also you put your extra bracing in ?
Provided the primary circuit is piped boiler - open vent - cold feed - pump, I don't see why it would be a problem.
Reply to advise on flow and return points unvented cylinder compared to the height of the header tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Trying to add a shower into a small bathroom, I'm looking at moving my hot water cylinder to the loft. Currently, I have a vented 200L cylinder...
I'd like to install an unvented cylinder in the loft. With limited headroom it would have to be horizontal. I want to keep my existing valiant...
2K
I have recently moved into a house with the following heating system: Traditional boiler (Worcester Greenstar Ri 24 with only one temperature...
We need an urgent advice, we have a gravity water system and we are in a middle of loft conversion. We are adding an en-suit in loft and prefer to...
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
