Discuss AIRFEL Single and Double Panel Radiators 12 years warranty ???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumberland
can someone please tell me why airfel panel radiators have 12 years warranty? I am about to buy a few Airfel panel radiators but i need some advise first. Thanks, Dave
coz thats what they think theyll last before having any problems:rolleyes:
Don't know. Some marketing idea probably. Any radiator will last 12 years with no problem. Even if it did pinhole, how many people would actually bother to claim it on a guarantee?
i now know !! Airfel panel radiators have zinc phosphate corrosion protection whereas others only have iron phosphate corrosion protection. I ordered a few Airfel Panel radiators and a plinth heater and will write more about them once i have received them.
The outputs they quote (see [DLMURL="http://www.akfel.com/upload/dosyalar/radyator_12_07_2006_eng_con.pdf"]Brochure[/DLMURL]) are based on a flow temp of 90C and return of 70C, which is not complying with BS EN442 (75C/65C) so the outputs will appear to be nearly 25% more than equivalent UK rads.
you are looking at the old brochure, I just checked the BTU values and they are DT50 ( 75C - 65C ) values according to BS EN442 (75C/65C) ( see new Airfel Panel Radiator [DLMURL="http://www.airfel.com.tr/images/kullanim_kilavuzu/PANEL%20RADIATORS.pdf"]brochure[/DLMURL] )
You could get the best of both worlds with Kudox radiators, 12 year warranty and higher outputs than Airfel.
I know kudox radiators, very cheap looking compact radiators and they are rattling. I have done the heat output comparison between kudox and Airfel, Airfel has higher heatoutput and much cheaper than kudox radiators
I have done the heat output comparison between kudox and Airfel, Airfel has higher heat output
Really?
Airfel 11PK 600 x 1000 = 934W
Kudox PK 600 x 1000 = 1026W
Stelrad Elite K1 600 x 1000 = 1000W
Airfel 22PKKP 600 x 1000 = 1712W
Kudox PKKP 600 x 1000 = 1788W
Stelrad K2 600 x 1000 = 1778W
Who are Kudos? Can't find anything about them. Where are they made? Who owns them?
Airfel is a Turkish company.
Hi doitmyself, it's Kudox not Kudos, I think plumberland is a buildnet spammer!
Reply to AIRFEL Single and Double Panel Radiators 12 years warranty ???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come...
M
  • Locked
My central heating system is well over 20 years old, but it's been working reasonably well until recently. Firstly it seemed the 3 way value...
MartinT
M
  • Locked
Hi all , firstly, what a great site , and the info i have learnt has already led me to tackle 2 problems succesfully , and although it took some...
2K
sophiesdad
T
  • Locked
I need a bit of advice before I make some alterations to my central heating pipework. The current arrangement is a closed system on a combi...
3K
tucker
T
