N
nysk2008
Priced up to replace (supply and fit) a new honeywell 4073a 3-port valve, I priced as £200 all in. bloke says hes been quoted £160, is my price really that bad?
Discuss am i charging too much? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Last one I did was for £140 for a genuine v4073a. In and out in 30 mins. Bunged tank, cracked nuts and sucked water up with wet vac swappy swappy no need for more inhibitor. If the valve is in a carp position and I can't snatch it I will drain system to be safe and therefore would charge a bit more. What are you paying for v4073a's ?
so he was expecting it for £150 or less then
Screwfix is never my choice unless stuck, price seems high for that 3 port
£200 for a weekend is fair IMO but you really shouldn't be paying anything near that for valves.
Ray is doing the valve for 82.80 all in
I know, but only recently s/e so gotta buy when the works in. also you know how cust change their mind every 2 secs so dont want to get a full van stock in
Reply to am i charging too much? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
