Discuss answers please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stevetheplumber
Subscribed
10.12 The recommended method of testing for leaks when assembling LPG equipment before use is to:
a. Test with the use of a manometer
b. Apply leak detection fluid to the connections
c. Use the sense of smell to detect the smell of gas
d. Listen for the sound of escaping gas
10.15 A job requires dismantling lengths of cast iron soil pipe at height, which of the following actions should be taken?
a. Working in pairs, break the length at the collar, and remove the pipe
section
b. Crack the pipe at the joint and push it away, making sure the area is clear
c. Smash the pipe into sections using a hammer and remove it piece by piece
d. Crack the pipe at the base, tie a rope to the pipe and pull the section down. Shout ‘below’ to warn others
the answers are c and a when i first read it i couldnt belive a manometer wasnt the obvious answer but when i re read it it makes sense as its more aimed at plant ie gas bottle and pot or gun
but taking down a stack is obviously now a two man job annd they obviously havent moved on with cutting disc technology i would have thought breaking cast was a no no
theres another question regarding removing a cast iron bath thats to heavy to lift and the answer to that is inform your supervisor dont know about anyone else but i dont think ive ever remove one in one piece
I removed a cast once in one piece with a mate. Was in good condition and wanted it for myself. Put it outside the house and in 5 minutes it was no where to be seen!!! Now I just get the sledge hammer out straight away
wouldnt have thought c is much good stood outside a mobile home in a stiff breeze (howling gale if you live in London) and your upwind, bit of leak detector fluid is what I rely on first off.
Question 1 is Really badly worded. First couple of times I read i thought it was asking how to test an lpg installation before it is made live. In which case if it is yet to contain gas how would you smell it.
NVQ Level two questions are of much the same poor standard of English.
Actually, rather disgraceful; which only serves to confuse, befuddle and stupify.
so the non english can understand it lol
Reply to answers please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
