Discuss Anti vac trap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
townfanjon
Subscribed
Evening chaps , never done this and it's all going behind a long wet wall.
A nats over 3 meters long horizontal soil pipe what has a ok 'fall' joints an internal soil pipe.
On the run are 2 toilets and 2 basins, rather than run 2 separate basin wastes all the way back to the soil pipe.
Can I use 2 anti vac traps on the basins and just use 2 strap on boss's with 2 short lengths of waste straight in to the pipe.
Thank you
Just use normal traps and In large the waste to either 1"1/2 or 2" depending on the actual length.
When we do this we use antivac traps, stops the other gurgling when one basin is let go, cheaper than using hepvo's to. As said upsize it to 1 1/2'' waste pipe to.
50mm wastes come on boys.... I would also run a 32mm vent back to the stack from an years facing tee between the sinks .
Worked for 100 years before fanny traps and anti symphonic
Nah I am trying to do away with a wall full of pipes.LOL
Depends what else was in the fizzy drink, something a little more hard core?
50mm is oversized for two basins in a domestic property? Have fun chopping that in the wall!
Reply to Anti vac trap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
In my last posting, I requested assistance in exchanging a waste that had been fitted using silicone, without actually removing the basin. Mission...
Good afternoon, please see my attached diagrams One is the current layout And one is where I propose to add another boss to add a shower waste...
Hi all. I'm just curious...why do bath traps use 40mm connections and pipework and yet basin traps use 32mm? I have a very short length (1.25m)...
Evening all. Not sure if this is the most appropriate place to post this in the forum, happy to move if not. I'm looking for a metallic 32mm...
