Discuss Anybody recognize the piping system in this photo? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
thepickleruk
I want to move a radiator in my house and had a plumber come round and have a look.
He said it was some sort of some special piping system that you need a special machine to join up. It is made up of 16mm piping.
He referred to it as what sounded like the 'upnull' system and said he wouldn't be able to help as he didn't have the special equipment needed to work with it.
However having done lots of google searches with different spelling of 'upnull' I can't seem to find anything out about it.
So does anyone recognize it? I am looking for someone in Exeter who may be able to work with it.
Many thanks.
These the official uponor fittings? Ive used before compression fittings, replacing the nuts and olives with uponor nuts and adaptors
Just ripped a load out in a refurb where the service engineers were installing Uponor stuff. Plastic compressed fittings and threaded unions to get back to conventional size pipes and fittings........not impressed tbh.
The pipe is great, however everything is expensive, i prefer using the compression fittings with the adaptors
16mm push fit stuff
Produktkatalog
I think it you get these push fittings you can cut the pipe and do the job without the tool. Or use the adaptors to convert it to 15mm pipe. Speak to Uponor to be sure.
16-15mm adapter push fit:
Produkt-Detail
That takes me back 12 Years, was the next best thing for about 6 months. ..
last time I came across this stuff i though ohh white plastic pipe snip snip went to put fittings on ohh b******s. had to hire the machine for a day. easy to use but a complete pain.
Reply to Anybody recognize the piping system in this photo? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
