Discuss Aqua scale inhibitor on cylinder cold fed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Simon.h
Hi all,
As you may know i have no hot water from Tribune Premier tank and as i checked the pressure reducing valve & strainer and now think its got to be the cylinder is scaled up. I have noticed there is also a Aqua dial combi scale inhibitor between the pressure reducing valve and the cylinder on the cold mains fed.
Is this right?
Is it a 22mm one and has it had a new cartridge it needs changing every 12months
Yes its a 22mm and was last changed at the end of 2009. So if i got one of these why is my cylinder scaled up?
Its over due a change then.
Is the cylinder scaled up? What are the symptons
Hi, no hot water pressure, if i turn hot tap on i get some water then slows down, so no baths or shower. I have removed and checked the pressure reducing valve & strainer and all fine and still have good cold pressure on 1st floor as this comes off the pressure valve.
How have you tested Pressure reducing valve, I think the problem must be that.
I have not tested the pressure reducing valve, but as the cold water for the 1st floor comes off after it and i still have got good cold pressure on all 1st floor taps/shower/bath.
there could be a blockage in the scale inhibitor - I'd check that first, and if it's ok I'd look for a plumber with his unvented ticket and a wetvac.
Well ive checked the scale inhibiter and the small holes which run to/back from the 't' to the cartridge looks blocked, but i have removed the 't' which is cut into the cold fed and its clear. So as i checked every thing in the cold fed to the cylinder it can only be a scaled up cylinder!
Why has it scaled up then ive got a scale inhibiter?
How will a wetvac help?
Simon.
if the scale reducer has the possibility of causing a blockage then its not a good idea to have it between the pressure relief valave and the cylinder. is the pressure relief valve before or after the scale reducer?
He said reducing, not relief. And yes, if it was relief that would indeed be bad!
Hi, Its between the cylinder and the reducing and pressure relief valve!
Reply to Aqua scale inhibitor on cylinder cold fed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
