Discuss Are all sink strainer wastes a universal size? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Including the ones that come with 1.5 and 2 bowl sinks. They tend to look like the rim and washer that connects to the underside of the sink are larger than on a standard 1 1/2 sink waste to me. But it could be cos they're usually white and standard wastes are black (slimming, I'm told)
To re-pipe this mess pictured below (which has a 32mm bottle trap presumably just so it'd fit - and it's now blocked) would two of these def fit?
Brushed Stainless Steel Sink Strainer Waste | NoLinkingToThis
The diameter of the flange of where the wastes sit on the underside of the sink where about 105mm.
No -you need one with the cable control for the pop-up plug (unless you do away with the cable pop up entirely).
If you do away with the popup, make sure that the basket wastes come with a blanking cap for the overflow inlet as only 1 of them has the overflow going into them. Next just get one of those universal 2 basin sink kits. If there isnt room for a P trap, then use a running trap further along.
I did think of putting a blanking piece there because it doesn't work and she wasn't fussed. I guessed I'd need a sink overflow blanking plug too. I'm really just wanting to know if these wastes are a universal size. As in - they'll fit every sink?
Provided the top part will fit into the hole, yes. I never had an issue with a modern sink. Maybe Ikea ones are different as post of their plumbing is?
Reply to Are all sink strainer wastes a universal size? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
  • Locked
Hi all, I feel defeated as cannot find a simple solution to this problem. I have installed a new sink in my kitchen, it is 12 bowl with a 90mm...
J
  • Locked
First post... here goes: We've acquired a second hand but lovely old sink which I've been tasked with plumbing in. The existing waste (plug/hole)...
  • Locked
Hi I'm working on a bathroom with some unusual stuff. They picked up an old basin, belfast ceramic style, small about half the size of a...
3K
T
  • Locked
Hello, I had 2 belfast sinks to install - 1 in the kitchen and 1 in the utility. They came with fairly standard looking chrome wastes. I...
3K
K
  • Locked
Hi all Apologies for ignorance - water has been backing up and leaking out of this fitting below a Franke 1.5 sink recently, where the blue cap...
5K
PlumbBobBob
