Discuss Are expensive compression fittings worth it in the USA area at PlumbersForums.net
Anj
I need to add a two port valve to an existing system. As part of this job I need to add a few compression fittings.
Wanted to ask those more experienced is it worthwhile buying (as an example) a Prestex (Pegler) 28mm equal T for £12.80 vs cheaper non-brand at £8.05? Is there real any difference in a compression fitting that justifies the additional cost?
Thanks in advance for any opinions
The cheaper one will be fine, just put a smear of jointing paste around the olive for peace of mind, although we would normally use capillary fittings, much cheaper and more reliable in a heating system.
12 sounds very expensive online search finds 28 mm for around £6 to 8 good makes and cheap even found 50 at £36.00 plus vat
I can't ever really remember looking at the cost of a comp fitting. Just buy them - and make sure they're not junk (you can usually tell just by a glance at the finish) as a general rule the bigger the size the fewer junk fittings are available.
Ok thanks I will follow that advice.
Do you all consider WRAS certification (eg for a Ball Valve) as anything to consider or do these fail just as much as any other...
Wras means it's been tested for water hygiene safety which I gather is quite an expensive thing for the mfr to do, so yes they are more likely to be better quality overall.
[automerge]1587494422[/automerge]
A brass olive suggests a better quality fitting over copper olive
I wouldn't, personally speaking, so long as they comply with BS 1254. If you're worried about failure, then go for a DZR fitting instead of standard brass. Fittings in general don't usually fail, in our lifetimes.
Reply to Are expensive compression fittings worth it in the USA area at PlumbersForums.net
Apologies for the stupid question, I'm just a newbie playing under the sink. I have an isolation valve and an elbow, both of which have...
3K
i notice on Pegler’s website that they don’t recommend jointing compound on their compression / Prestex fittings and i wonder what people’s...
I wonder if anyone can help, I've tried several plumbers merchants to no avail. I have removed an old stopcock, (which seized long ago, with a...
2K
Hi again I'm on a roll with the plumbing questions today! So here's query #2... We've not used our hot water for quite some time, and it now...
2K
Hi, Any help or opinions appreciated on this topic. Summary - last year bought a 90’s build house that had a wet UFH heating system designed and...
2K
