Discuss Are these fitting used here in the UK? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone please advise whether we use this type of plumbing fitting/stopcock here in the UK....
https://i.*********/V8kvLg8.jpg
https://i.*********/J5Nskme.jpg
Many thanks :)
Looks like a 1/2 extension
And something like that yes
Thank you ....so a yes to the 1/2 extension (are they commonly used in that scenario - in a shower control 'standoff'?)
Was that also a yes to the stopcock with a 'slot end' ? (again if so, are they common?
Yes and no, they are but not normally on show normally if you use a back plate 1/2 extension and then the adapter to the shower valve
Yes two types most common is a straight online service valve but you can get them angled
Reply to Are these fitting used here in the UK? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with the experience I have picked up over a lifetime. I can make copper pipe runs isolaters taps sink shower etc but me and the missus have bought a small...
Hi all I’m a newbie here so please be gentle 😇 I’m in uk and recently bought a house with a few plumbing issues and hope that this forum can help me sort them out I’m pretty good with diy so can’t see any problems doing any work myself Will be posting the problems I’m having shortly 👍
  • Article
The UK Government has today been told to do better when it comes to Heat Pumps and Hydrogen Boilers. A watchdog for spending has said that the Government in the UK needs to do more to make green energy heat pumps and other green central heating options more affordable for the UK customers...
Hello, I'm considering fitting an isolator valve to 15mm feed to my toliet cistern. It would require cutting off an existing compression fitting for a flex hose, after which I'd only be left with maybe an inch and a half of pipe. I've never fitted a compression fitting before, can someone...
