M
moony
went to view a ariston combi 27mffi last week keeps going to over heat lockout it was for a friend and i only had 5 minutes to have a look - i opened up the nearest rad and it was fine for a few days - i said the pump may be on the way out but as i say i only had 5 mins to check it out.
he has now bought a pump on that prognosis.
anyone had any dealings with this - do the temperature stats go on these - it sound slike a definate circulation problem to me but im thinking the temp stat may be faulty too?
any thoughts - im going back weekend as its quite far from me - i may get a temp stat if theyre prone to failing on this - hes also going to give the system a slude remover treatment tmrw night and let it run for a few days and i'll drain and change pump on weekend - anything i should check and if any of you have had any dealings with this then let me know.
cheers
moony
cheers
moony
