Discuss Atmos intercombi he32 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
markymark99
Hi all
New to forum. Off to a boiler breakdown on Atmos intercombi he 32. Not worked on one of these before, apparently no CH, anybody experienced with these ?
Hi Harvest fields, thanks for replying.
Have put my GSR details in when signing up for forum ( only joined tonight ) . Will I be contacted when I’ve been checked ? or am I best to send details over as you suggested?
Cheers Mark
Send me a pm via the contact
With your gas safe reg number
In the meantime you need a min of 10 non spamming posts easy enough to do introduce your self in the welcome section etc
Reply to Atmos intercombi he32 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
Hi. I recently had a renovation done. My builder installed a new Combi boiler instead of my system boiler. He connected the pipework to the digital pump. He did not inform us that we would need a new processor because we had changed to a Combi and subsequently a valve blew. Should my builders...
Hi all,new to the forum and hoping to get some guidance through the boiler minefield . We moved into a 70s bungalow last Feb,its got a Greensted 241 junior mark 3. The expansion tank has failed, also it has a Boss therm sender unit wired to it but the previous owner didn't leave the receiver...
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
Hi can anybody help me with a problem I am having. following a power cut the heating and hot water failed. The boiler would light but it would go out because of no flow. I thought it was the programmer blown because if it wasn’t calling for heat or hot water it doesn’t trip the electric,but as...
