Discuss Auto bypass valve problems. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mickie
I've read the baxi duotec and the 600 boilers already have a Integral bypass but I've seen overheat problems with the 600 boiler when the lad has turned but one radiator off with 8mm pipework and I've also seen a pump fail after 2 years on a baxi duotec.. I assume a bypass should solve these issues ?
Pumps failing no that’s a grundfos issue bad batch that keeps popping up so more do to with the new ones
Depends on the size of the rad should be sized to suit min working output
Reply to Auto bypass valve problems. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have read that an Auto Bypass Valve (ABV) is not compatible with a pump set to Proportional Pressure (PP) mode. I have a recently fitted...
2K
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
1K
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
1K
Hi Guys I had UFH added to my extension, my system was a Baxi 30he with CH and unvented cylinder. The UFH has never really worked correctly...
1K
Hi there, I recently bought a bunch of Drayton Wiser Smart TRV heads. I wanted to install them on all of my radiators so that I have full control...
3K
