Discuss Back boiler is boiling! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
djboyd
Hi all
I have a link up system with a dunsley neutraliser. This is connected to a sealed unvented hot water cylinder and a standard gravity fed and pumped central heating system. Both my back boiler and oil fired boiler feed to the neutraliser. The hot water system is protected by plenty of safeguards against overheating - must be pumped, valve, overpressure regulated, etc. The only safeguard against the back boiler overheating is the stat on the neutraliser set at 90 C. This stuck again tonight meaning I could hear the boiler releasing steam into the header tank as the pump did not trigger circulating the heat through the rads. So, two questions:
Is there any additional safety device I could use to stop the system boiling (especially during power cut)?
Does it matter if it does boil, dumping the boiling water into the header tank?
Thanks for your help.
No replies? I just want to know if it is safe to boil off now and again or if I should do something!
Thanks for the reply. Yes, I was aware of that case - my system has boiled probably twice in the last few years when the anti-boil stat has not activated. My concern is that during a power cut or another failure it will continue to boil. I suppose that as it boils off the water is released as steam and the ball cock allows cold water in to replace it, keeping the temp in the tank below 100. Thought there might have been some additional mechanical method to dump the boiling water somewhere else.
Reply to Back boiler is boiling! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
PSxxxxxx
