Discuss Basic Room Stat needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Aqua Mechanica
Just after a basic room stat, needs to cover the ancient potterton one I have now that is 95mm wide and 70 odd mm high. It must be at least 95mm wide as the room has just been decorated and there will be a hole either side of the thing if not.
Does anyone know one that will do the trick please?
Ben
Or, we currently have a programmer next to the boiler, perhaps I can get a combined programmer/timer/room stat instead and place it where the old room stat is?
yes you can get combined units.
honeywell's are the most common and expensive
sunvic so a very good unit half the price.
both come with change over wiring diagrams.
Well the 70mm is no problem,it is the 95mm wide bit,how about getting a normal
honeywell room thermostate and just putting a bit of plastic beading each side for now ,it will look ok and when they redecorate,(which if anything like my wife will be in a few months time !! )they can remove beading or get a fingure plate to put behind it like you can ge for backs light switches
I would definately recommend a programmable stat, it gives so much better control and will cover the hole left by the last one.
Reply to Basic Room Stat needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
  • Locked
I have a Potterton Performa 24 Eco HE combi, and the integral analogue timer clock is jammed. I want to fit a new Honeywell CMT927 RF programmable...
2K
Ermintrude
E
K
  • Locked
I have to have a serious money talk with some local heating engineers, but need to know something of which I speak. Your comments would be most...
2K
J
  • Locked
I developed a fault on my Potterton system as a direct result of trying to change the in room stat (Potterton PRT2) with a new Honeywell DT90e...
5K
judge
J
  • Locked
Hi there, thanks for taking the time to read this, and hopefully help. i moved into a new (old) house last year, and we have a central heating...
3K
T
