Discuss Bath and shower waste into same pipe? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Total refit of of bathroom. I've got a 40mm waste from the shower running beneath the floorboards to an external wall and out. Just above where the pipe exits is where the obvious place for the bath waste to exit as well. Should I use separate waste pipes for the bath and the shower or can the bath waste join into the shower waste from above (e.g. using a swept 90deg joint)?
My first thought was fine, crack on, then I was worried about water from a deep bath being emptied into the waste and as the water level was higher than the shower trap, it all emptyin out into the shower tray.
Is it OK to join into the existing Shower waste pipe or should I run a second waste out through the wall?
Thanks.
I always prefer separate wastes where possible.
If the shower waste has correct fall, combining them should be an issue. However, I’d want to join them and run the rest of the line to the stack in 2 inch. Use a wye rather than a tee to connect them.
Also, there could be the risk of letting a full bath go and it pulling water from the shower trap. That depends on trap seal depth, pipe size and pipe distance between the two.
Safest option is a separate line.
Reply to Bath and shower waste into same pipe? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, grateful for any advice I need to connect a dishwasher waste water outflow pipe 25mm to 50mm waste pipe. Is there a joining piece anyone can...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
Hi, came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting. The fittings at...
Hi, As per title we have a regular smell from the shower trap. Clean the trap twice a week, had a cleaning rod down the shower waste pipe and no...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
