Discuss Bath drain problems plastic snapped in the USA area at PlumbersForums.net
Hi All,
Have accidentally snapped something plastic that the bath drain screws into. Can anyone tell me from the attached images what the y shaped plastic is called and if I can replace it? Or if anything else can be used instead as a replacement?
Thanks,
Craig
Darren is correct you can rectify the problem with one of these . Kop
Reply to Bath drain problems plastic snapped in the USA area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Sonya K
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
